975755 Posts in 138933 Topics by 6360 Members - Latest Member: TattooedYorkie September 22, 2024, 03:19 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  how to remove a sticker thats fitted and sprayed over with clear? ?
Author Topic: how to remove a sticker thats fitted and sprayed over with clear? ?  (Read 1385 times)
Offline Nicfred
how do you remove a sticker that has been fitted then sprayed over with clear?  :(
can it be done or am i screwed  :'(  :'(  :'(  :'(  :'(
Re: how to remove a sticker thats fitted and sprayed over with clear? ?
« Reply #1 on: September 11, 2007, 10:51 AM »
yep yer screwed, could try using a razor of craft knife round the edge then use heat (like one of those little jet cigarette lighters) over the decal to get it really hot n melt the glue n peel off with tweezers, but ya gonna be left with a decal shaped indent where you took it from, which you could sand over with really fine paper and re clear coat, but its gonna take patience to get it right
Offline Nicfred
« Reply #2 on: September 11, 2007, 11:44 AM »
yep just wot i thought,bugger it and blast,thanx  :LolLolLolLol:  :2gunsfiring_v1:
2020mad
« Reply #3 on: September 11, 2007, 11:49 AM »
put a bigger sticker over it.  :LolLolLolLol:
Offline Nicfred
« Reply #4 on: September 11, 2007, 11:50 AM »
thought about that,i got a big white roll of duct tape  :LolLolLolLol:  :LolLolLolLol:
Offline Del
  • Re-living my youth!
« Reply #5 on: September 11, 2007, 11:52 AM »
do you just want to cover it? if so what colour is your frame?
Offline Nicfred
« Reply #6 on: September 11, 2007, 11:56 AM »
not really,id prefer to remove it,(but the pri*k has sprayed over it so looks like a complete respray)its on a 1981 looptail quad i got from the states so wanted to do it right,worst bit is its only just been painted so only this sticker spoiling the frame?
but looks like im screwed and will have to get it painted  :'(  :'(
Offline Del
« Reply #7 on: September 11, 2007, 12:12 PM »
what about just rubbing down the clear coat where the sticker is, take the sticker off then get someone to spray over the bit where the sticker was with clear coat again and blending it in, I'm sure that can be done?
Offline Nicfred
« Reply #8 on: September 11, 2007, 01:06 PM »
mmmmmmmmmmmm,didnt think of that  :-[, suppose i could try that,got nothing to lose,cos if i mess it up i just paint it again  :LolLolLolLol:  :LolLolLolLol:
here goes then angle grinder out,goggles down  8) ,here goes   >:D  :LolLolLolLol:  :LolLolLolLol:
thanx  :daumenhoch:
ill give it a bash
Offline Del
« Reply #9 on: September 11, 2007, 02:07 PM »
get a before and after pic, I'd be quite interested if you manage to do it.
