975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 06:11 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  stem/ headset novice question
Author Topic: stem/ headset novice question  (Read 522 times)
slimsteve-o
« on: September 06, 2007, 09:18 PM »
ok here is tonites novice question, the forks for my bike have a threaded 1 inch diameter top shaft. do i just need any old school 1 inch type headset? will i need to get a specialist to press this in for me? also, ive noticed stems advertised for sale with and without the wedge, are these different types of stem, or just some with the wedge missing? any advice would be cool.  the bike is a peugeout, i think the model is 401. cheers.
steve
adeshere
Re: stem/ headset novice question
« Reply #1 on: September 06, 2007, 09:46 PM »
Hi,
Any old skool headset should fit.
To fit the cups, its best to use a vice. hammers and bits of wood have been used, also large washers and a thick bolt with nuts on each end, then tighten away. I'd recommend the vice option.
Stems - are you confusing new skool with old skool. Old skool need a wedge
slimsteve-o
« Reply #2 on: September 06, 2007, 10:00 PM »
ok, cheers mate.
