975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 08:41 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  help complete novice problem with gt
Author Topic: help complete novice problem with gt  (Read 479 times)
ja
« on: August 22, 2007, 09:52 AM »
the problem i'm having is when pedaling its fine one minute then it'll slip pedals go round but the wheel dont, so is it a prob with the rear sproc, it has skyways on it....so is this a easy fix or a shop job....
wildwood1971
Re: help complete novice problem with gt
« Reply #1 on: August 22, 2007, 11:15 AM »
SOUNDS LIKE YOU NEED A NEW REAR FREEWHEEL TO ME - JUST SIMPLY REMOVE AND USE A NEW SHIMANO OR SUNTOUR ONE - THERE ABOUT £10 - £15 ON THE BAY. MIGHT NEED TO SOAK THE OLD ONE WITH WD40 AND THE USE A REMOVAL TOOL OR HIT WITH AN OLD SCREWDRIVER AND HAMMER - THE NEW ONE WILL TIGHTEN ITSELF WHEN YOU HAVE REPLACED IT BY PEDALLING AS HARD AS YOU CAN - HOPE THIS HELPS
PAUL
Jazzchimp
« Reply #2 on: August 22, 2007, 12:45 PM »
You can also buy coaster replacements from rudewheels if you want
