975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 09:05 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  P*ssed off with F**kin skyways
Author Topic: P*ssed off with F**kin skyways  (Read 1551 times)
Offline se-bmxer
« on: August 10, 2007, 04:33 PM »
Got these blue skyways im trying to get the braking marks off the rim,
so far tried wire wool with hob cleaner next will be the fookin chizel (god knows how to spell it)
any magic formulas out there guys
snav69
Re: P*ssed off with F**kin skyways
« Reply #1 on: August 10, 2007, 04:37 PM »
I got the marks off my white ones with a stanley knife blade , just dragged it across a few times  :shocked:
 :coolsmiley:
FuNMoNsTeR
« Reply #2 on: August 10, 2007, 04:43 PM »
wet n dry... use coarse grade for starters to get all the marks out and then a couple of finer grades to finish smooth  :daumenhoch:
Offline bodamus
« Reply #3 on: August 10, 2007, 04:43 PM »
Steel wool WD40 and Washing up Liquid very hot water worked for me.
Bodamus ;)
« Reply #4 on: August 10, 2007, 04:43 PM »
sir stanley is the way to go
alfie
« Reply #5 on: August 10, 2007, 04:44 PM »
i told you to put some blue brake blocks on
Offline Del
  • Re-living my youth!
« Reply #6 on: August 10, 2007, 04:46 PM »
yep as others have said, stanley knife blade, just scrape away
Offline se-bmxer
« Reply #7 on: August 10, 2007, 04:50 PM »
Cheers guys stanley knife it is.
alfie i did they don't fit very well on v brakes :2gunsfiring_v1:
« Reply #8 on: August 10, 2007, 06:04 PM »
easy way is to bolt axle in a vice so ya can spin the wheel
and then ya get a even finish then
Offline funkyfresh
« Reply #9 on: August 12, 2007, 08:21 PM »
I found mde grit wet and dry worked well, but left them dull...a  little car wax that is slightly abrasive bought them back to the correct shine though
« Reply #10 on: August 14, 2007, 02:28 PM »
apparently if you put them in the freezer, it will straighten them, clean off the brake rub marks, regrease the hubs, find your car keys, walk the dog, and put the "ram" in the rammer dammer ding dong
« Reply #11 on: August 14, 2007, 02:36 PM »
Not to be confused with the bop-she-wop-she-wop.................. they are only wheels after all.
therock
« Reply #12 on: August 14, 2007, 02:43 PM »
iv got the same problem on my light blue skyways on my quadanngle , all i did was fly round the block and keep breaking so that it gets an even black mark all the way rouns so it looks like its meant to be there ( no seriously i did) job done  :daumenhoch:
« Reply #13 on: August 14, 2007, 03:00 PM »
classic, way funny!!  :LolLolLolLol:
