975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 09:22 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Prizing Seat Post Clamps Apart……..
Author Topic: Prizing Seat Post Clamps Apart……..  (Read 630 times)
Offline brass monkey!
« on: August 01, 2007, 11:32 AM »
Prizing Seat Post Clamps Apart…….. to get it over the seat post tube ?  :)
Any tips on how to prize apart or widen a seatpost clamp, without damaging it. I have a Hutch Donut in Chrome, so need to be gentle with it……! So, no hammer or screw-drivers !! LOL !! (I think I had the hammer/screwdriver discussion with S.B. Dan and Mr Stupps at Daggers recently)
Any tips then ?  ;)
Offline Waxintaxin
Re: Prizing Seat Post Clamps Apart……..
« Reply #1 on: August 01, 2007, 11:35 AM »
I used a screwdriver and cloth and kinda twisted / screwed it on , it was tight and it was a hutch duffnut
« Reply #2 on: August 01, 2007, 11:36 AM »
make a wooden wedge then tap down from underside .
use a piece of wood and slice it down to a bit of a point     ie an old broom handle
« Reply #3 on: August 01, 2007, 11:37 AM »
buy another one the correct size?   ::)
Offline Stodgy
    • RADBMX Shop
« Reply #4 on: August 01, 2007, 11:39 AM »
I had the same problem with a Hutch donut.
Pulling it apart didn't work, so I got my trusty Dremmel and a smalling sanding tube and worked around the inside a couple of times. Hey presto, fitted with no visible scars.
« Reply #5 on: August 01, 2007, 11:48 AM »
thanks guys, i'll try those out........ ;)
Offline Dingobmxer
« Reply #6 on: August 01, 2007, 12:29 PM »
take the bolt right out, thread it in from the otherside (outside) place a thin peice of steel in the gap and as the bolt goes through it will push against the steel therefore pushing the clamp apart AND you can regulated the force used by how tight you screw in the bolt, works with clamp on stems too  :daumenhoch:
 :) DINGO :)
« Reply #7 on: August 01, 2007, 12:40 PM »
Genious!!   :daumenhoch:
highrisedrifter
« Reply #8 on: August 01, 2007, 12:46 PM »
 :) DINGO :)
That's a cracking idea, mate.  :daumenhoch:
Thanks for that.
HRD
