975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 03:25 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Chain tensioner on Skyway TA
Author Topic: Chain tensioner on Skyway TA  (Read 597 times)
Stevo
« on: July 29, 2007, 09:11 PM »
I have waited 2 years to complete my TA and want to get it right. I want to fit old school chain tensioners, should the 'washer' go in or outside the drop out?
I think they should go on the outside, if it's inside I would need force the drop outs apart a bit.
Re: Chain tensioner on Skyway TA
« Reply #1 on: July 29, 2007, 09:12 PM »
i run them on the outside mate!
but either way will do
Stevo
« Reply #2 on: July 29, 2007, 09:44 PM »
Cheers, I think I will do the same. Running them on the inside would take too much force.
highrisedrifter
« Reply #3 on: July 29, 2007, 09:45 PM »
Outside, mate.  :daumenhoch:
andrewthomas197
« Reply #4 on: August 06, 2007, 11:07 PM »
Outside.
Stevo
« Reply #5 on: August 13, 2007, 08:07 PM »
Fitted them the right way, but the right one slightly touches the freewheel.  :(
So I only run the left one. Pity that. But it still works.
« Reply #6 on: August 14, 2007, 02:52 PM »
could you stash a washer either side to slightly space it out?
if the freewheel is fouling the tensioner, make sure it isn't also catching the dropout
Stevo
« Reply #7 on: August 14, 2007, 11:53 PM »
Thanks, I could use washers but it's tight as it is. Do want to force the drop outs too much on the old TA.
