975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 02:59 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  How low can I go ?
Author Topic: How low can I go ?  (Read 2554 times)
Offline billstup
How low can I go ?
« on: November 10, 2005, 06:35 PM »
I`ve just purchased an odyssey free coaster to have laced in to a hazard rim, the trouble is that it only comes with a ten tooth driver, so I will need to change my chainwheel to a 28 tooth.
Now, my brake lugs are on the lower part of the rear triangle so the chain may snag on it, and my question is what is the lowest brake that I can get that might cure this problem ?
Re: How low can I go ?
« Reply #1 on: November 10, 2005, 06:45 PM »
prob the fly or primo e brake
and i have heardyou can get a lowering kit
or somit for ya brakes ?  ???
fatboymal
« Reply #2 on: November 10, 2005, 07:10 PM »
Billy,
Fly, check out the S&M LAF at Pijin with Fly brake and 28T:
Not to mention that they work brilliantly and are lightweight..
« Reply #3 on: November 10, 2005, 08:45 PM »
depends on frame geometry. on mine, the oddy evolver fouled with a 30 tooth wheel so probably will on yours. the lugs are the same height no matter what you put on it tho......what ratio were you running before the freecoaster?
Offline billstup
« Reply #4 on: November 10, 2005, 09:38 PM »
I`ve got 36-13 at the moment which gives plenty of room.  ;)
Sanmarcopizza
« Reply #5 on: November 11, 2005, 10:24 AM »
Bill, if you need to try it out, I have a Primo E-brake on my Pashley....which is residing at Bobs house at the mo.
« Reply #6 on: November 11, 2005, 10:53 AM »
a 36 will run on mine, but not a 30. a 30 fouls the brake.
Andy
« Reply #7 on: November 11, 2005, 12:43 PM »
Billy
Even with a fly brake your chain will hit the brake
Im assuming your still running the T1.
The chainstays on the LAF are a lot lower than yours thats why it works. From memory I think the lowest you can go is about 33t
Andy
« Reply #8 on: November 11, 2005, 12:57 PM »
thats what i thought. the lugs are the same no matter wot brake you get.
its whether the chainstays are low enough.
Andys Mrs
« Reply #9 on: November 11, 2005, 07:59 PM »
Obbie
The brakes make a load of diff, A fly brake has a minimal stacking height, if you compare it to an oddy evolver the difference is massive the same goes for the primo E brake but I know what your saying about the difference in chainstays, I think you can o as low as 25-9 on a panterra if you use a fly, unfortunately for billy his T1 wont accomodate the hub he wishes to use.
Time to get a new frame I think Bill
Andy
« Reply #10 on: November 11, 2005, 08:01 PM »
andys missus, you seem remarkably in tune with bmx shennanigens....
Offline Rombloke
  • do one
« Reply #11 on: November 11, 2005, 08:09 PM »
he must be rubbing off on her
Dave
haro, how do you do
Offline Rombloke
  • do one
« Reply #12 on: November 11, 2005, 08:09 PM »
no that didnt sound right!!!!!
Dave
haro, how do you do
Offline billstup
« Reply #13 on: November 11, 2005, 09:45 PM »
Obbie
Andy
B*ll*cks, I purchased a fly rear brake and tree 28 chainwheel last night from ace cycles and now you tell me it won`t work, just better thank my lucky stars that it was about half price what it would have cost me over here  :(
« Reply #14 on: November 11, 2005, 09:48 PM »
heh heh,....................
« Reply #15 on: November 12, 2005, 12:31 AM »
put 44/16 on it bill.we never had any problems with that  ;D.
fatboymal
« Reply #16 on: November 12, 2005, 06:40 PM »
What colour did you buy? I may buy them off you if they are no good.
Offline billstup
« Reply #17 on: November 12, 2005, 07:30 PM »
The usual new school colour Mal..........black.
I will be using them though, even if it means getting a new frame  ;)
fatboymal
« Reply #18 on: November 12, 2005, 07:36 PM »
No worries, quite fancied a green set (mine are grey). They work so well, they are just superb.
So next question, which frame you going for?? :)
Offline billstup
« Reply #19 on: November 12, 2005, 07:54 PM »
Proper Proclaimer with spanish b/b and intergral  headset, not sure what top tube length to have though, my T1 is only a 20" and I quite like the way it rides  :)
fatboymal
« Reply #20 on: November 12, 2005, 08:16 PM »
Short as you can man, it feels like old school frames (but way better with the short rear end, if that makes sense). My Fly simple is less than 19" and it feels great.
