975808
Robertflamn
November 26, 2024, 01:19 PM
gyro problem on internal headset
Topic: gyro problem on internal headset (Read 480 times)
harris
Founding Fathers
Hoffman's Love Child
July 20, 2007, 03:10 PM »
does anyone use a new school frame with internal headset and a gyro.
as mine seems to tight to go over headset.
Trev
Re: gyro problem on internal headset
July 20, 2007, 03:19 PM »
i think billy bmx does.
BrianP
Cherry Picker
July 22, 2007, 01:00 AM »
I do Dan,
Odyssey GTX on a wtp phoenix works fine. BUT I did have problems in the past with a snafu mobeus detangler on a fly pantera...
Bp.
harris
Founding Fathers
July 22, 2007, 07:25 AM »
i will try a gtx then as a normal steel gyro wont go over head cup,its same size .
i did file inner gyro and it just slipped over very tight.
July 22, 2007, 10:23 AM »
i use gtx's on 2 bike that have internal headsets and they are ok.
also with a gtx you cut the upper cable lengths
run a dragonfly gemini upper cable and the gyro setup will work BETTER than a straight cable
