975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 08:48 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  skyway axle *****NOW WITH PIX*****
Author Topic: skyway axle *****NOW WITH PIX*****  (Read 594 times)
Offline priv
« on: July 17, 2007, 10:20 AM »
i've got a front plastic hubbed skyway i'm thinking of using but the cones don't tighten up properly on one side,it's the washer that holds the bearings in place that's worn,do i need to buy a full axle kit or does anyone just sell the washers.
i hope this makes sense,if not i'll get a pic up tonight to show the problem better
priv
« Last Edit: July 17, 2007, 07:05 PM by priv »
adeshere
Re: skyway axle
« Reply #1 on: July 17, 2007, 03:26 PM »
Cant you just use a normal washer ? or is it a special shape
pic would help
Offline priv
Re: skyway axle *****NOW WITH PIX*****
« Reply #2 on: July 17, 2007, 07:08 PM »
a bit blured but i hope you get the idea
priv
Offline Del
  • Re-living my youth!
« Reply #3 on: July 17, 2007, 07:30 PM »
do you mean these Ady?
Offline priv
« Reply #4 on: July 17, 2007, 08:07 PM »
that's them del,are they supposed to be so loose that i can take them out with my fingers
like this
or is there another washer that goes on top to seal it between to cones nut and bearing cup
priv
Offline Del
« Reply #5 on: July 17, 2007, 08:10 PM »
no they should be a tight pressure fit, they're there to keep the bearing in/give them some protection from crud, the cone should spin freely within the hole of it.
Hope that makes sense
Offline priv
« Reply #6 on: July 17, 2007, 08:50 PM »
Thanks del,if i get a new axle kit would that fix it?
priv
Offline Del
« Reply #7 on: July 17, 2007, 09:06 PM »
if you want you can have those 2 cup washers, I dont need them. just pm me if you want them.
