975792 Posts in 138942 Topics by 6363 Members - Latest Member: Bmxflex November 12, 2024, 03:56 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Tight Stem Bolt
Author Topic: Tight Stem Bolt  (Read 594 times)
Trev
Tight Stem Bolt
« on: July 11, 2007, 09:57 PM »
Okay guys, easy one for ya.  One of my stem bolts is really tight.  So tight I can see the allen key starting to bend when try to undo it.  what is the best way to loosen it?  wd40?
also, do you know if all, i suppose they are called hollow fork bolts now (formally known as hollow stem bolts) are different sizes or not.  I need to replace one.  Sh1Tstanleys were supposed to have sent me a replacement one months ago, but now i have given up all hope from them.
cheers.
Re: Tight Stem Bolt
« Reply #1 on: July 11, 2007, 10:02 PM »
i use a socket alen key on a ratchet  ,better pressure but can snap easy.
wd will help
Re: Tight Stem Bolt
« Reply #2 on: July 11, 2007, 10:04 PM »
Also, see if you can get a centre punch into the the allen head and hit it with a hammer to break the "weld" on the threads  :daumenhoch:
Trev
Re: Tight Stem Bolt
« Reply #3 on: July 11, 2007, 10:05 PM »
yeah, i've got something that will give it more leverage, but i think i'll need stronger allen keys.  you could tell these were about to snap with just me pulling on it.  fooking cheap homebase tat.
Trev
Re: Tight Stem Bolt
« Reply #4 on: July 11, 2007, 10:05 PM »
would that cause any damage?
Re: Tight Stem Bolt
« Reply #5 on: July 11, 2007, 10:11 PM »
If you use a flat ended centre punch then no, it shouldn't damage it at all  :daumenhoch:
Mind your thumb though won't you!
username
Re: Tight Stem Bolt
« Reply #6 on: July 11, 2007, 11:24 PM »
Have you tried tightening the other 3 bolts to release the tension on the the one thats stuck?
Trev
Re: Tight Stem Bolt
« Reply #7 on: July 11, 2007, 11:28 PM »
there's only two on this one.  ???  i did think about doing that, but got worried in case that one got stuck too...
