could you take a close up pic and list the exact parts used to do it,
Quote from: rarman1 on July 11, 2007, 06:14 PMcould you take a close up pic and list the exact parts used to do it,use 1 1/8" forks, 1" cups, 2 sets of 1" headset balls (put them in the cups loose, you get almost 2 sets in each cup - not packed to tight though, as you will get a tight spot)then use the rest of the top parts of the aheadset
I had a bit of that action.welded 990 mounts on the rear, fitted 1 1/8th forks, slicks, prolines dirty harry's, slams, primo walls, acs freecoaster etc, it was a good workhorse.
