975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 12:21 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Skyway TA frame material
Author Topic: Skyway TA frame material  (Read 502 times)
andrewthomas197
« on: June 20, 2007, 01:17 PM »
Can anyone confirm that there is no aluminium content in the frame material, I'm about to get the chrome stripped and the company have scared me. I'm pretty sure it will be ok but just need it confirming.
Thanks
Re: Skyway TA frame material
« Reply #1 on: June 20, 2007, 01:36 PM »
Chromoly Tubing. 4130 aircraft quality steel.
« Reply #2 on: June 20, 2007, 01:40 PM »
From Wikipedia, the free encyclopedia
Chromoly is an abbreviation for "chromium-molybdenum steel" (sometimes spelled "cro-mo"). Chromoly is a range of low alloy steels used, for example, to produce tubing for bicycle frames and race-car roll cages. It is not as lightweight as aluminum alloys, but has the advantages of high tensile strength and malleability. It is also easily welded and is considerably stronger and more durable than standard 1020 steel tubing.
One of the most common chromoly steels is 4130 steel, composed of 0.28 to 0.33% carbon, 0.4 to 0.6% manganese, 0.8 to 1.1% chromium, 0.15 to 0.25% molybdenum, 0.04% phosphorus, 0.04% sulfur, and 0.2 to 0.35% silicon, in addition to iron.
Although chromoly contains chromium, it does not have the corrosion resistance of stainless steel.
andrewthomas197
« Reply #3 on: June 20, 2007, 09:52 PM »
you're good.
thanks for this....
