975854 Posts in 138949 Topics by 6381 Members - Latest Member: Caravanman January 23, 2025, 03:37 AM
RADBMX.CO.UK  |  Forum  |  Q&A, Ideas & Feedback  |  How to apply formats, post hyperlinks etc
Author Topic: How to apply formats, post hyperlinks etc  (Read 1444 times)
Offline TrickyDicky
« on: July 19, 2005, 09:42 AM »
Some people seem to be having difficulties with formatting etc.  There's a really easy method for this:
Select the text you want to apply the formatting to with your mouse (Click and drag):
Some blurb
Then click the button you want (eg Bold)
If you want to apply more formatting, select Just the text again:
...and click on another button. Same process for apllying quote tags, hyperlinks etc etc
The thing to remember is to just select the text only each time (click and drag), being careful not to select the tags as well
Easy eh? ;)
Re: How to apply formats, post hyperlinks etc
« Reply #1 on: July 19, 2005, 10:17 PM »
Quote
Easy eh?
no not really i did'nt understand a word of anything above at all.please do it again in thicko terms please.im not the only one neither by the ammount of pm's i've got  ;D.
greentoad
« Reply #2 on: October 29, 2005, 12:39 AM »
Hi
How do we insert a Click Here but insert a hyperlink please, eg www.radbmx.co.uk
Thanks
Offline showtime
« Reply #3 on: October 29, 2005, 10:11 AM »
like THIS ONE  ;) you mean?
you can even turn pics into links, click my Kuwie banner to see :)
for a click here text prompt on a hyperlink you need to obviously use the link tags
the tags [url*]and the closing tag with the / inside it.     the tags [url*][/url*]  (ignore the * symbols i added them to stop the tags working) but the tags look like that but without the *!
normally to add a link you just use the tags & write the web adress between the ] & [ brackets between the 2 tags
this will give you a hyperlink with the web address as the highlighted text, just making sure you got that first ;)
to add different text like a click here etc to the link you need to open the tags as normal [url]....and the other but dont write the web adress between the two ][ you need to do it like this then you have your click me here and then close the tags as usual with the [/ur*l] without the *
the close tag always has the /url but inside the[ ]
so basically its adding a = symbol & the web address into the first tag then adding your "click me" prompt between the tags!
hard to describe but hope it helped ;)
« Last Edit: October 29, 2005, 10:22 AM by showtime »
Offline ORB
« Reply #4 on: October 29, 2005, 11:25 AM »
12
12
greentoad
« Reply #5 on: October 29, 2005, 11:52 AM »
Hi got it cheers  ;)
I used to work on Dreamweaver but it's been a while  :-[
so for web use  = for Rad click here
This is an example of how to do it -
[ url=http://www.radbmx.co.uk ]for Rad click here[ /url ] NO SPACES BETWEEN TAGS
so for email use  = click to email
[ email=you@yourdomain.co.uk'subject=Rad BMX ]click to email[ /email ]  NO SPACES BETWEEN TAGS
Hope this helps others  ;)
greentoad
« Reply #6 on: November 03, 2005, 12:37 AM »
man you still got me lost. i dont know what any of it means  :-[.
