975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 07:52 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Does anyone know the axel size of a redline proline crank
Author Topic: Does anyone know the axel size of a redline proline crank  (Read 1010 times)
BMXBEN
Please so i can buy replacement bearings :daumenhoch:
Re: Does anyone know the axel size of a redline proline crank
« Reply #1 on: June 16, 2007, 11:03 PM »
Ben, just checkin, is it pro lines or flites you have?
« Reply #2 on: June 16, 2007, 11:58 PM »
Tone, think they are Pro-Lines he has - got them of  Motomag2
« Reply #3 on: June 16, 2007, 11:59 PM »
So they are bigger than flites which are 19mm, sorry cant help any further :(
« Reply #4 on: June 17, 2007, 12:16 AM »
I'm pretty sure they are a 20mm diameter, so a standard Odyssey one should fit  :daumenhoch:  If it's just the bearings that are shot then there should be a number on the seal that you can take to a bearing shop and a 141 replacement  :daumenhoch:
darkersomeday
« Reply #5 on: June 17, 2007, 12:51 AM »
have a look at the 400 series in ratty's thread, i'm fairly sure theyre 20mm,
if you need a spare i've got one here if its any good,
BMXBEN
« Reply #6 on: June 17, 2007, 10:47 AM »
Cheers lads the bearing casings have been fitted with a hammer & there shot to bits & one of the bearings is crap too. I put an engineers ruler across the centre hole & it says 21mm. they are redline prolines i got off motomag :-\
« Reply #7 on: June 17, 2007, 11:06 AM »
Ben, I had a similar problem with one of my BB's, I got my mate to put them on a lathe and skim the outer surface then I wnet to work with wet and dry before polishing them - the outers look like new now although the insides are not so pretty but no-one sees those when they are on.
BTW, on your bearings is there a very thin top-hat style washer pressed in?
BMXBEN
« Reply #8 on: June 25, 2007, 05:07 PM »
Hi cant see any top hat washer pressed in although im not entirley sure what your on about. i could probably get away with new bearing cups but again i dont know what size one's to get :-\
« Reply #9 on: June 25, 2007, 08:37 PM »
they are 20's
i have some 20mm bearings for euro cups (no cups though) that will fit them, if you are gonna run a euro BB
alans sells 20mm bearings that allow you to use them in a spanish bb
