975755 Posts in 138933 Topics by 6360 Members - Latest Member: TattooedYorkie September 24, 2024, 12:18 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Them's the Brakes !
Author Topic: Them's the Brakes !  (Read 507 times)
Offline Stace
Them's the Brakes !
« on: June 12, 2007, 10:34 PM »
How do ya stop the fekers screaming when ya pull ya ickl lever?
Does by bonce in  :idiot2:
Offline BrianP
Re: Them's the Brakes !
« Reply #1 on: June 12, 2007, 11:24 PM »
fookin does my head in too stace!
you need to "toe in" your brake pads a wee bit.
try and get the front of the brake blocks to hit the rim slightly before the rest of them.
should do the job (except for fakies... ) plus it should improve your braking.
Brian.
« Reply #2 on: June 12, 2007, 11:36 PM »
Toe them in as Brian says, using an adjustable spanner on the caliper place it above or below the brake block (which ever has more room) and tighten it up (the adjustable) so it grips it well, then gently turn the spanner towards your rim so that the leading edge of the brake block is closer to the rim than the rear edge of the brake block but only just (a couple of mm will do).  What will then happen is when you brake the rotation of the wheel will pull the brake block onto the rim and should eliminate any squeeling  :daumenhoch:
gt0733
« Reply #3 on: June 12, 2007, 11:55 PM »
wrap them in tape before you do this to stop the ano being scratched :daumenhoch:
