975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 06:56 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  fitting an acs freecoaster to a skyway coaster.
Author Topic: fitting an acs freecoaster to a skyway coaster.  (Read 1051 times)
« on: November 01, 2005, 11:08 PM »
always use a good quality tea.
undo the locknuts, take out the cone and let the hub drop on your shed floor spreading bits of coater into hard to reach places. when u have gathered it all up it may look like this
then as if that werent difficult enough you get this as well.
stick the bits back together with grease....and slip it in the orifice
plop the driver in. and the bearing..small not big, thats already in...keep on yer toes now lads..
think about reading the instructions, then decide against it....
cone washer, washer and locknut..small not big....thats spare now....
align the sprocket thing with the 3 grooves...
pop the seal washer in and screw it in with your "special tool"
jobs a guddun!!!!
post thread on rad knowing full well that youll probably be the last person ever to do it, and probably the first since 1986...
cool as.
tune in next week when we split the atom, prove that black is white, and attempt to make a working volcano from bogroll and caustic soda.
Offline billstup
Re: fitting an acs freecoaster to a skyway coaster.
« Reply #1 on: November 02, 2005, 12:19 AM »
PhilI`d put some bolts in that hub before using it  ;)
BTW I`ve just bought an Oddy freecoaster from Alans  ;)
Offline BrianP
« Reply #2 on: January 10, 2008, 02:51 PM »
 :4_17_5:
Bp.
ps that is one clean setup!
