It's no problem at all, as long as the parts are still available.....You can buy converter cups to fit either fork into either frame. 1 1/8th forks into a 1" frame was quite a common job as people wanted the strength and clamp on stem option before having to upgrade their frame.A ring around should see you right, try Billys up in Cambridge - I think their distributor used to make their own converter cups.Hope that helps Don't forget to buy suitable bearings as well......
would have to mess with a few headsets to get the right combo, you would need a 4" unthreaded headset, and a dooslem pin
