975755
TattooedYorkie
September 22, 2024, 08:40 AM
burner headset problem
Topic: burner headset problem (Read 1148 times)
May 31, 2007, 06:26 PM »
hi guys i finished my burner porject but when i went to go ride it the forks had loads of play in them. can anyone help??
spesh
Re: burner headset problem
May 31, 2007, 06:29 PM »
did you use a db headset from halfrauds?because the bottom race is bigger than the burner one hence lots of slack
spesh
May 31, 2007, 06:31 PM »
i dont think i used a db one
probs though, what do you sugest i do to stop it
spesh
May 31, 2007, 06:35 PM »
whip the forks off and check the fork race to see if its slack on the forks
ideally you should change it but in the meantime you can make a sleeve using coke cans and shim the bottom race to take out the slack
spesh
May 31, 2007, 06:47 PM »
thanks m8
selfpreservation
June 01, 2007, 12:43 AM »
they were all like that BITD
Voodoocars
June 01, 2007, 07:38 AM »
Measure the diameter of the forks where the crown race has to fit.It has to be a pretty acurate measurment so use a micrometer or good calipers.Then give this place a call, they have everything. Chandos Hub and Rim Co. 01279 758718
Ian.
