976202 Posts in 138987 Topics by 6419 Members - Latest Member: BMXBoyBrookie March 19, 2026, 08:54 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  please help ...chain ring bolts....
Author Topic: please help ...chain ring bolts....  (Read 1126 times)
dodgydave
« on: May 30, 2007, 05:11 PM »
got a powerdisc ..cant get the bolts undone ..a bit rounded & turning at back ...anybody any ideas ..how to get them off ..cheers guys dd
Re: please help ...chain ring bolts....
« Reply #1 on: May 30, 2007, 05:15 PM »
the threads are really short on them bolts
they don't usually cause any probs
try some wd40
boiling water could free them too
GREMLIN
« Reply #2 on: May 30, 2007, 07:10 PM »
I always use one of these Sugino chainring bolt tools whenever tightening, un-tighteneing etc.
Fits in and stops the back of the bolt turning. Only cheap online too. Saves using a screwdriver or pointy object, which usually for me ended up slipping and stabbing myself or scraping the chainring/spider/powerdisc.
If you get your hands on one of these you should find the bolt will undo quite easily. Even if you have to tap a screwdriver into the rounded out allen key holes.  :daumenhoch:   G.
