975755
TattooedYorkie
September 21, 2024, 09:11 PM
chainring fitting
Topic: chainring fitting (Read 463 times)
thesku11s
chainring fitting
May 26, 2007, 11:02 AM »
Hi,
I have never owned a bmx square taper 5hole type crankset.
I want to use a bmx chainring on a road bike im building (to run a bmx chain)
but wanted to check if the five hole fitting on sugino bmx chainrings is the same as mtb/road bike ones?
darkersomeday
Re: chainring fitting
May 26, 2007, 11:11 AM »
should be fine as long as it 5x 110mm spacing?,
whats the roadbike? fixie?
thesku11s
May 26, 2007, 03:17 PM »
indeed it is
will go and buy some then,
suppose i can resell if they dont fit.
- its an old stronglight cransket by the way.
chainring fitting
