975762 Posts in 138935 Topics by 6360 Members - Latest Member: TattooedYorkie October 01, 2024, 04:05 AM
RADBMX.CO.UK  |  Mid School BMX (>87) 1989 to 2003 (<05)  |  Mid School ( Keep the faith )  |  hoffman info please
Author Topic: hoffman info please  (Read 1108 times)
motomagII
hoffman info please
« on: May 25, 2007, 09:23 AM »
can anyone do me some pics spec and any info they can on hoffman flash please thansk you guys .dates around 96 i think
scooby74
Re: hoffman info please
« Reply #1 on: May 25, 2007, 09:30 AM »
http://www.airfreetires.com/specs/Step5.asp?BikeId=708&Brand=Hoffman&Model=Flash+Pro&Year=1999
BB Shell Width: Unspecified
BB Spindle Length: Unspecified
Bicycle Type: BMX
Bottom Bracket: Unspecified
Brake Levers: Dia-Tech MX-1 rear
Brakeset: Dia-Compe VC-747 rear brakes, Dia-Tech MX-1 rear levers
Chain: KMC 410, 1/2 x 3/32"
Chain Size: 1/2 x 3/32"
Chainrings: 44
Chainstay Length: 14 1/8-15 5/8"
Colors: Anodized White, Chrome-Plated, Orange
Component Group: Not applicable
Crankset: 1-piece chromoly, 44 teeth
Fork Brand & Model: Hoffman Bikes Flash
Fork Crown: unicrown
Fork Material: 4130 chromoly, unicrown crown
Fork Rake: 0.0"
Fork Travel: Not applicable
Frame Angles: 74.0 head, 70.0 seat
Frame Construction: TIG-welded
Frame Tubing Material: 4130 chromoly
Front Brake: Not applicable
Front Brake Lever: Not applicable
Front Derailleur: Not applicable
Front Derailleur Type: Not applicable
Handlebar: Hoffman Bikes Racing Bars
Handlebar Extensions: Not applicable
Handlebar Stem: Hoffman Bikes Super Stem
Head Tube Angle: 74.0
Headset: 1 1/8" threadless Dia-Tech steel
Headset Diameter: 1 1/8" threadless
Hub Front: Mount
Hub Rear: Mount
Hubs: Mount
Largest Rear Cog: Not applicable
Num Rear Cogs: Not applicable
Pedals: Wellgo LU-313U
Rear Brake: Dia-Compe VC-747
Rear Brake Lever: Dia-Tech MX-1
Rear Derailleur: Not applicable
Rear Shock: Not applicable
Rear Shock Travel: Not applicable
Rim Front: Araya 7X
Rim Rear: Araya 7X
Rims: Araya 7X, 36-hole
Saddle: Velo 309
Seat Post Diameter: 25.4mm
Seat Tube Angle: 70.0
Seatpost: HB aluminum, 25.4mm diameter
Shift Levers: Not applicable
Sizes: Unspecified
Smallest Rear Cog: Not applicable
Spoke Brand: steel, 2.0mm straight gauge
Spoke Gauge: 2.0mm
Spoke Holes: 36-hole
Spoke Material: steel
Spoke Nipples: brass nipples
Spoke Type: straight gauge
Sugg Retail: 419.99
Tire Front: Tioga Comp III
Tire Rear: Tioga Comp III
Tire Size Front: 20 x 1.95"
Tire Size Rear: 20 x 1.75"
Tires: Front: 20 x 1.95" Tioga Comp III, Rear: 20 x 1.75" Tioga Comp III
Top Tube Length: 19.75"
Weight: Unspecified
Wheelbase: 35.75-37.25"
Offline Stodgy
    • RADBMX Shop
« Reply #2 on: May 25, 2007, 09:59 AM »
motomagII
« Reply #3 on: May 25, 2007, 10:21 AM »
checked the tt length its 20 inch 11/8 ahead .wasnt going to build to spec just wondering what they were speced like and looked like etc .
so far ive got araya 48s on then removed and put me camo rims on and thats as far as ive got as i havent got stem bars or headset for it .gonna be ridden at track etc so will have to be built for me rather than to spec
