975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 12:05 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Removing Shimano SX End Caps
Author Topic: Removing Shimano SX End Caps  (Read 485 times)
Paulo
« on: May 24, 2007, 05:32 PM »
I want to de-anno my old sx pedals using the oven pride trick...can't wait, so I'm stripping down the pedals.
I'm assuming the first step is to remove the plastic end caps, but they're not budging. :rant:
Am I right and is there an easy way of popping the end caps without screwing them up with a screwdriver?
Offline Steve P
Re: Removing Shimano SX End Caps
« Reply #1 on: May 24, 2007, 05:39 PM »
A very thin screw driver should pop the caps out ... SX are painted BTW, not anodised  :daumenhoch:
Steve
Paulo
« Reply #2 on: May 24, 2007, 08:27 PM »
Got the ends off thanks Steve. Because of the grinding wear around the caps ends the burs as it were were holding it in.
Paint it is cause the oven pide did f-all. Right where's that paint stripper? :LolLolLolLol:
