975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 09:27 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  URGENT HELP!
Author Topic: URGENT HELP!  (Read 920 times)
brettnai
URGENT HELP!
« on: May 22, 2007, 08:41 PM »
I'm just fitting the headset to my Streetbeat, which is my first build from absolute scratch, I'm petrified of fooking it up.
I've bashed in both headset cups and now wanna fit the other bit (dunno whats its called) to the top of the forks, is there an easy way of doing it? will it just slot over as I tighten it up? or is it another hammer job?
need to know asap, its sat in the garden waiting to be done
ta
« Last Edit: May 22, 2007, 11:01 PM by brettnai »
Re: URGENT HELP!
« Reply #1 on: May 22, 2007, 08:43 PM »
The bottom race should be a tight push fit, if not then drop it in boiling water for a minute, then quickly fit, should expand it enough to fit :daumenhoch:
Re: URGENT HELP!
« Reply #2 on: May 22, 2007, 08:44 PM »
man ring me before you bash anything else
brettnai
Re: URGENT HELP!
« Reply #3 on: May 22, 2007, 08:47 PM »
Cheers mate
I'll go try!
Offline Moose
Re: URGENT HELP!
« Reply #4 on: May 22, 2007, 09:03 PM »
A bit of pipe with a slightly larger bore than that of the fork steerer - try an old hoover pipe (but I think that worked on my new school forks for inch an eighth)?
« Last Edit: May 22, 2007, 09:14 PM by Moose »
Re: URGENT HELP!
« Reply #5 on: May 22, 2007, 09:06 PM »
i use an old hand chopper.........not a bike lol.
nice and thin and its heavy enough to knock it on nicely.
Jazzchimp
Re: URGENT HELP!
« Reply #6 on: May 22, 2007, 09:12 PM »
Get a piece of copper pipe (15mm plumbing stuff), push the ring on tap it down using a hammer and the pipe. The copper is so soft it won't damage the ring, failing that light taps with the hammer will work but take real care cos that's the race for the bearings!!!
sonic-1
Re: URGENT HELP!
« Reply #7 on: May 22, 2007, 09:31 PM »
heat ring cool the fork  it will slip strait on no tapping required
brettnai
Re: URGENT HELP!
« Reply #8 on: May 22, 2007, 09:37 PM »
All sorted!
Cheers guys!
Just promise me you wont tell the missis what happened to the hoover!
Really appreciate your help!
Re: URGENT HELP!
« Reply #9 on: May 22, 2007, 09:37 PM »
If youve got a big bench vice, open the jaws up so they are just wider than the steerer tube. Then get the bottom bearing race started so it kinda holds in place. Hold the forks upside down with one fork leg in each hand. Hold the forks with the upside down steerer tube hovering inside the vice jaws. Then SMASH the forks down into the vice, so the bearing race hits the top of the jaws. Repeat till the race is all the way down, rotating your angle of attack such that the race sits flat.
This method tends to scratch the outside of the steerer tube, often marks the bearing race surface, and sometimes leads to a cracked bearing race which means you gotta buy a whole new headset.
OK, dont do it this way, but it is the way I fitted the last one I had to do (sorry to my 24" pitchforks!)  :crazy2:
Offline ORB
Re: URGENT HELP!
« Reply #10 on: May 22, 2007, 09:38 PM »
Gas axe and a sledge hammer.
12
highrisedrifter
Re: URGENT HELP!
« Reply #11 on: May 22, 2007, 09:43 PM »
Offline Moose
Re: URGENT HELP!
« Reply #12 on: May 22, 2007, 09:50 PM »
All sorted!
Cheers guys!
I said old hoover pipe - not your missus's favourite Dyson pipe  :LolLolLolLol:
Offline ORB
Re: URGENT HELP!
« Reply #13 on: May 22, 2007, 09:54 PM »
Will your Mrs still suck without the Hoover?
12
brettnai
Re: URGENT HELP!
« Reply #14 on: May 22, 2007, 09:56 PM »
yeah she sucks!... but in a 'life sucks' kinda way haha!
Re: URGENT HELP!
« Reply #15 on: May 23, 2007, 08:24 AM »
the I.D of a set of new skool forks ids usually the same as the OD old skool forks, so slip a pair over and tappa tappa tappa
