975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 08:27 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  oh bugger!
Author Topic: oh bugger!  (Read 693 times)
oldgit1
oh bugger!
« on: May 08, 2007, 07:45 PM »
Started stripping my robinson down and found that the seat post is well and truly rusted in,anyone got any tips for gettin them out.
Re: oh bugger!
« Reply #1 on: May 08, 2007, 08:01 PM »
if you dont want the seat post heat it up with a blow lamp
wait till very hot and cool the frame with cold water
then twist the seat post with a stem bolted to it
if that dont work fill the seat tube with diesel
and leave to soak .plus make sure nole holes in the bottom bracket
as will drain away
oldgit1
Re: oh bugger!
« Reply #2 on: May 08, 2007, 08:47 PM »
as will drain away
Cheers fella think ill give 2nd potion a try,dont want to loose the post(gt layback) :daumenhoch:
zed4130
Re: oh bugger!
« Reply #3 on: May 08, 2007, 08:50 PM »
if you or a freind has a vice ,just grip the post and twist away  :daumenhoch: plenty of wd40 aswell  :daumenhoch:
