975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 08:37 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Tuf Neck Stem Help.
Author Topic: Tuf Neck Stem Help.  (Read 496 times)
ligbee
Tuf Neck Stem Help.
« on: May 04, 2007, 09:44 PM »
I've just bought a bike with a Tuf Neck stem on and am having trouble removing it. It has a quill bolt which I've removed and tightens up on what looks like a 23/24 mm a/f hexagonal bolt head, does this want removing before the stem will come away?.
ligbee.
Re: Tuf Neck Stem Help.
« Reply #1 on: May 04, 2007, 09:48 PM »
No just undo the small bolt & you may have to give it a tap with a soft faced hammer to loosen the wedge.
If it has been in there for a long while, spray something like WD40 down the stem shaft.
ligbee
« Reply #2 on: May 04, 2007, 09:52 PM »
Whats the large hexagonal component for then?.
ligbee.
« Reply #3 on: May 04, 2007, 09:52 PM »
That holds the shaft onto the stem  :)
ligbee
« Reply #4 on: May 04, 2007, 09:53 PM »
ligbee.
