975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 11:16 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Dents & Dings ?
Author Topic: Dents & Dings ?  (Read 814 times)
Offline Stace
Dents & Dings ?
« on: April 19, 2007, 06:57 AM »
So you gat a few f&f you wanna rstore but they've got the odd knock on them.
How do you deal???  Can you get the dent out or do you fill??
Stace  :daumenhoch:
Re: Dents & Dings ?
« Reply #1 on: April 19, 2007, 07:36 AM »
if for just show stace i fill ,but if you powder coat the filler can lift.
i have had some drilled and pulled with heat but very carefully.
some ive had the tubing replaced.
Offline jT Racing
  • i like bikes. :/
Re: Dents & Dings ?
« Reply #2 on: April 19, 2007, 08:03 AM »
what i do is drop a weld in then carefully grind back. This is somthimg that needs to be done by an experienced welder. Cro mo tubing is paper thin on old school bikes and you can burn through in a flash! I have seen that a lot of frame repair's are done by throwing a small braise in too. Easily done by the right people.
ding dong
