975804 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 02:30 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Haro Group 1 stem bolts
Author Topic: Haro Group 1 stem bolts  (Read 660 times)
electro808
« on: April 17, 2007, 11:07 PM »
I'm in the process of restoring a pair of Haro Grop 1 stems and they are pretty much sorted.  One has a polished base with a white cap and the other one has a polished base and cap.  Only problem is, the original stem bolts are rusty and are only fit for the bin.  Any ideas on where I could source some stem bolts to add the finishing touches to my blingin' stems.  I'm sure the Anlun/Group 1 bolt head is a bit bigger than a Tuf neck style stem bolt.  I tried some Tuf neck stem bolts on the Group 1 and there was a bit of movement due to (I guess)  the bolts heads being slightly smaller...
