Dan, I will be bringing it along, thanks for the offer mate and fingers crossed.Rhys, took it to a shop and they had the same freewheel remover as me, and couldn't get it off either.Marty, the bearings are sealed. I have had the axle off and checked it and it all seems fine.I need to get the freewheel off to change it and work out what it is from a process of elimination. It is not the chain as I tried a different rear wheel and it was fine.
I'll check mate. Sounds very plausible. Can you buy sealed bearing races?
Just use the other wheel then Jim, the noise will go then
Is it a sealed suntour hub? There is someone on the burner forum who can get the replacement bearings for those.Check out this thread, very useful:http://www.raleighburner.com/phpBB2/viewtopic.php't=5284&highlight=suntour+sealed+hub+restoration
