975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 08:06 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Gyro cable
Author Topic: Gyro cable  (Read 1345 times)
adeshere
Gyro cable
« on: October 21, 2005, 11:30 PM »
Hi,
Anyone attempted to take a gyro cable apart ?
I'm sure it wouldn't take much heat to get the cable out of the cast piece
OR, does anyone know where to get long blue upper gyro cables from. Long ones only seem to be black
The-flying-banana
Re: Gyro cable
« Reply #1 on: October 22, 2005, 12:01 AM »
yes and it cant be done unless you solder the end back on the cable :-\ well new school ones anyways dont know about the older ones ;)
Offline graeme
Re: Gyro cable
« Reply #2 on: October 22, 2005, 11:37 AM »
im using a gyro, orgy type, and there aint no way to get the cable outers off unless, not if you want to be able to use it again after.
So i painted the barrels and used electrical tape on the cables.
If you take your time it looks good. You wouldnt know without getting very close.
Dont spiral wrap the cables in tape, use one piece donw the length of the cable, much neater.
Cheating i know, but it does the job for now till what you want turns up.
