975755
TattooedYorkie
September 22, 2024, 03:03 AM
Removing knackered allen bolts
Topic: Removing knackered allen bolts (Read 645 times)
the stag
March 16, 2007, 04:36 PM »
…rescued another bike from the tip today – anyone got any ideas how to remove an allen bolt from the stem, that has worn away inside and the key is just spinning in there?
Thanks for your help
kdw712
900 Air
Re: Removing knackered allen bolts
March 16, 2007, 04:44 PM »
If you can get a dremel in there what about grinding out a slot to get a flat blade screwdriver into
or grind awway the entire bolt head - i had to do that with XCii and the hex head cage bolts
cheers Kev
{ wanted : "Red Haro Handle" brake lever
link to my trade post
the stag
March 16, 2007, 04:47 PM »
i like the slot idea - good thinking - will give it a bash when i get home - thanks very much
kdw712
900 Air
March 16, 2007, 04:48 PM »
can't beat grinding a nice slot
cheers Kev
March 16, 2007, 04:51 PM »
get a slightly larger splined bit and whack that in
the spline tool for undoing vw drive shafts is just a whisker over 6mm.
get one of them!
sonic-1
March 16, 2007, 04:54 PM »
i to use spline drive hamered into the wrecked allen head
