975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 01:35 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Sealed Headset Bearings
Author Topic: Sealed Headset Bearings  (Read 612 times)
Offline Wayne Ryder
« on: March 13, 2007, 01:05 PM »
Just bought a Standard via eBay. The seller kindly included the sealed bearings on the BB & headset. Trouble is, I've never used one before.
The lower race looks like it'll just accept the curved flange (couldn't resist using that word) at the bottom of the forktube. The top one, I'm not so sure of.
Will the top part of my existing Aheadset  (an FSA Pig, I think) fit the Pig Pro, or would it be easier & cheaper to just transfer the loose-ball stuff over and not use the sealed set?
Re: Sealed Headset Bearings
« Reply #1 on: March 13, 2007, 01:06 PM »
sounds like an internal headset?
Offline Wayne Ryder
« Reply #2 on: March 13, 2007, 01:15 PM »
Is it? Not seen one up close to compare.
The cups are just like a regular headset, maybe a little smaller in the case of the top cup, the only difference are the bearings themselves.
Here's a shot from the auction itself:
Item No. 280087651511 if you fancy a look.
« Reply #3 on: March 13, 2007, 01:18 PM »
ive got sealed on mine, your right the only diff is the bearings.
Offline Wayne Ryder
« Reply #4 on: March 13, 2007, 01:25 PM »
Cool, then the stuff I've got should slot straight in.
Hate it when a job's held up because of something like that.
« Reply #5 on: March 13, 2007, 01:25 PM »
no its not internal
just use ya loose ball set, if you have all the parts
MeddlE
« Reply #6 on: March 16, 2007, 12:23 AM »
The cups for the Pig Pro (sealed) and Pig (loose-ball) are different, had the same problem myself recently.  IMHO the Pig is the better headset.
