975807 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 02:31 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Fitting Redline Flights
Author Topic: Fitting Redline Flights  (Read 578 times)
Superkav
« on: March 06, 2007, 10:55 AM »
I just bought these Flights from colouredtuffs.com and I'm having an absolute mare fitting them, they're my first venture into 3 piece cranks :-[ I have the cups, axle and sleeve in already...that bit was easy.
So now I have a pair of 1mm wahers and a pair of 1.5mm washers, a large machined black spacer and a smaller machined black spacer.
For the drive side do I fit a washer next to the bearings then add the large black spacer then the crank arm? Help! no fookin instructions in the box...plus I'm a coont
LXIX
Re: Fitting Redline Flights
« Reply #1 on: March 06, 2007, 11:28 AM »
you only use what you need with the washers for the drive end to line the chain up on the free wheel you might not need the all
« Reply #2 on: March 06, 2007, 11:36 AM »
just fit what you need to. the big black one probably goes on the non drive side.
« Reply #3 on: March 06, 2007, 11:40 AM »
As the guys have said, fit the big black one on the non-drive side and the small black one on the drive side then use whatever spacers you need to fill up the gaps, you may need them all or none at all.
