975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 26, 2024, 10:02 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  V-Brake lugged frames
Author Topic: V-Brake lugged frames  (Read 1024 times)
« on: February 26, 2007, 08:58 AM »
Do you have to run v-brakes on race frames, or can you set them up for freestlyle brakes and which to go for if you can. Do I recall,Mr Spacefruit that you were setting up a new Ripper for freestyle? what brakes will be /are on it?
Cheers, Simon :daumenhoch:
Re: V-Brake lugged frames
« Reply #1 on: February 26, 2007, 09:00 AM »
if you have v brake lugs, you need to run a v brake or cantis
ad 990 lugs are in a different position
i run v brakes on the back of my ripper for over 4 years with no trubs. only mither was that i couldnt run a gyro
« Reply #2 on: February 26, 2007, 09:18 AM »
yeah the ripper was for freestyle, (rippergate)lol...
as ruler says, you need to run v's or cantis. but they are good brakes, and work well.
the main reason for the freestyle ripper, was weight, its light as fook, has 1/8th forks, and has sealed hubs, and a cassette so izaak can change the gearing right doen if he wants to, to lose more weight.
probably not good for gyro, but, you can just run a long rear cable, as this will wrap round a couple of times, especially if you get a linear slick cable, which perform well under this stress.
rakas17
« Reply #3 on: February 26, 2007, 12:30 PM »
why cant you put a gyro on v brakes? aint it just a case of pulling the cable? ???
« Reply #4 on: February 26, 2007, 12:56 PM »
the v brake requires more pull
look closely at a v brake lever - it's different to a normal one
« Reply #5 on: February 26, 2007, 12:58 PM »
also, my ripper is internal headset, so would not take a normal gyro i dont think...
« Reply #6 on: February 26, 2007, 01:03 PM »
it should do
my ilegal is internal headset too. nice headsets, they are!
« Reply #7 on: February 26, 2007, 01:05 PM »
i thought you had to put external gyro lugs on it?
« Reply #8 on: February 26, 2007, 01:08 PM »
yeh maybe thats right you know
motomagII
« Reply #9 on: February 26, 2007, 06:56 PM »
i spent ages trying to set gyro up on me bulldog and in the end i gave up too much pull on the lever /calip to work long cable in the end .but man they are the best brakes ever once set up right they stop you on dime as they say .too keen sometimes even  greg
« Reply #10 on: February 26, 2007, 06:57 PM »
990's are better
at least you can feather them
v's are good for skids
Offline Dingobmxer
« Reply #11 on: February 26, 2007, 09:28 PM »
If you are using V's buy the Avid lever with the thumbwheel adjuster then you can dial in "feel" as it adjusts the leverage ratio  :daumenhoch:
 :) DINGO :)
« Reply #12 on: February 27, 2007, 10:30 AM »
Thanks for all the info people, much appreciated :daumenhoch:
