975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 10:51 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Profile crank bearing spacer tube?
Author Topic: Profile crank bearing spacer tube?  (Read 1027 times)
Offline Moose
« on: February 25, 2007, 04:10 PM »
Do they make different lengths?
I have 2 pairs of Profile made GT 3pc cranks and the bearing spacer tube on both sets are too short?  ???
LXIX
Re: Profile crank bearing spacer tube?
« Reply #1 on: February 25, 2007, 04:13 PM »
yes europe and usa?
Offline Dingobmxer
« Reply #2 on: February 25, 2007, 04:14 PM »
yup they do two lengths BUt are normally too short anyway  :uglystupid2:
what I do is use the thin spacer washers INSIDE the BB to get the correct length
 :) DINGO :)
« Reply #3 on: February 25, 2007, 04:15 PM »
yes  moose ,i have other makes the same problem.some people cut them down also
some bb are narrower than others .so you will find they will be good on some frames and not others.
or space them.
LXIX
« Reply #4 on: February 25, 2007, 04:28 PM »
  :wtf:  cut a new tube same dia different lenght ,spacers are only for the drive end to get your chain lazer straight,did you people race bikes?
dan-dare
« Reply #5 on: February 25, 2007, 04:55 PM »
W@nker.
B/B's are different widths, so spindle tubes may need reducing to suit. Spindle washers may be required if tude is too short. Vernier calipers are useful to measure.
LXIX
« Reply #6 on: February 25, 2007, 04:58 PM »
 :wtf: you talking about? im trying to help , a pece of tube cut at a different length and same diameter will do the job,washers are only for the chainwheel end :idiot2: as for the spline that can be hacksawed too
« Last Edit: February 25, 2007, 05:00 PM by LXIX »
Offline Waxintaxin
« Reply #7 on: February 25, 2007, 05:07 PM »
Or dont use them at all , and be careful when tightening the final arm
Offline Moose
« Reply #8 on: February 25, 2007, 05:08 PM »
Mark (LXIX)
I think what Dan-Dare and the others are saying is that it doesn't matter whether you use the tube on it's own or put a washer in there - the important thing is to ensure that the distance between the bearings has no gaps (otherwise the crank arms pinch on bearings and make them tight).
Having said that, if I can find a longer length of tube to cut down, I will  :daumenhoch:
Thanks gent's
LXIX
« Reply #9 on: February 25, 2007, 05:09 PM »
exactly what you get in the box dont meen you have to use all, use your own inicitive or somthing  :LolLolLolLol:
« Last Edit: February 25, 2007, 05:11 PM by LXIX »
Offline Moose
« Reply #10 on: February 25, 2007, 05:39 PM »
Solving the problem is not an issue - I just wanted to know why I have two pairs with a tube that's too short?
Too long, that I can understand, but too short is just stoopid  :idiot2:
I've found the answer anyway  :daumenhoch:
LXIX
« Reply #11 on: February 25, 2007, 05:40 PM »
and it is?
Offline Dingobmxer
« Reply #12 on: February 25, 2007, 05:47 PM »
at least we know the difference between a spacer tube and a Euro/US BB  :LolLolLolLol:
 :) DINGO :)
Offline Dingobmxer
« Reply #13 on: February 25, 2007, 05:51 PM »
AND I always find the drive side spacer too wide to get a good chainline so use the very thin washers that come with redline cranks, and I pop the bearing seals out and pack the bearings with good quality grease because Profile bearings come with virtually no grease in them  :uglystupid2:
 :) DINGO :)
Offline Moose
« Reply #14 on: February 25, 2007, 05:53 PM »
and it is?
There are two lengths for USA BB 51mm & 53mm.
LXIX
« Reply #15 on: February 25, 2007, 06:09 PM »
 :) DINGO :)
i have only had this problem since building bikes in england,why do you people have to make things complicates pounds ounces,metric imperial,witworth? mm inchesetc  :wtf:
