975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 09:48 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Redline flight dimple/non-dimple spindle
Author Topic: Redline flight dimple/non-dimple spindle  (Read 774 times)
Offline Haro82
« on: February 08, 2007, 09:56 AM »
Does anyone out there know the difference between a dimple spindle and non-dimple spindle on 401's. Why are the dimple one's supposed to be better etc...   ???
Cheers for any info.
Re: Redline flight dimple/non-dimple spindle
« Reply #1 on: February 08, 2007, 10:04 AM »
i've wondered that myself.
i've got the dimpled one with my set.
Offline boofy44
« Reply #2 on: February 08, 2007, 01:10 PM »
the dimpled ones are thicker and dont have the threaded bits just welded on each end
Offline Haro82
« Reply #3 on: February 08, 2007, 01:32 PM »
If they dont have threaded bits does that mean you can't put a threaded bottom bracket on it.
Frosty
« Reply #4 on: February 08, 2007, 02:25 PM »
yup, if no threads then it should be the sealed version
Offline boofy44
« Reply #5 on: February 09, 2007, 02:24 PM »
they are threaded,the threaded bits are separate rings welded on each end.i,ll try and get a picture up.
Offline Waxintaxin
« Reply #6 on: February 09, 2007, 02:42 PM »
The dimpled spindle is the correct one for the full wraps
the non dimple is newer , although the wrap fits this as well , the dimple is era correct
Rich
« Reply #7 on: February 09, 2007, 02:48 PM »
I have had a few pairs of "real" flights over the years. We used to grind out the dimple (its filled with weld) on the 401 spindle and remove the threaded section all together, meaning you could use a sealed BB and not have to buy a new redline spindle.
Not a story a collector wants to hear really.
