975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 26, 2024, 10:07 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  *********************** Another silly chroming question
Author Topic: *********************** Another silly chroming question  (Read 871 times)
YGT
« on: February 05, 2007, 12:58 AM »
If I took a raw frame, and replaced a few tubes - is there anything i shouldnt do if i want it chromed?
Obviously I dont want scratches shown in the chrome ... so do i need to paint strip it and pre polish it?
If so what is the procedure to pre polish and prep it?
Offline sawzall
Re: *********************** Another silly chroming question
« Reply #1 on: February 05, 2007, 05:59 PM »
the chromers should do all the prep work :daumenhoch:
« Reply #2 on: February 05, 2007, 06:33 PM »
You'd expect a good chromer to but judging by some of the horror storys we've had on here don't bet on it.
« Reply #3 on: February 05, 2007, 10:04 PM »
Get it dipped by the chromers or get it sand blasted and then go over the frame with wet and dry yourself making sure you are happy with the bare frame before letting the chrome plate be applied.  A good chromer will do all the prep work but expect it to be expensive that way.  Best to do most of the major work yourself and then agree with the chromer the bits you want/need him to do.  The quality of the finish is dependent on the preparation and the way in which the chrome is applied.  You need to make sure that a show chrome finish is applied, this will usually be a base layer of brass, then nickel and then the chrome.
mark j
« Reply #4 on: February 12, 2007, 02:25 AM »
This guide will give you an idea of the process and some tips.....
http://www.qualitychrome.co.uk/chroming.htm
