975757
TattooedYorkie
September 26, 2024, 11:51 PM
Old School BMX 1980 - 1988
Hub question
Topic: Hub question (Read 735 times)
badbuckle
Hub question
February 03, 2007, 02:58 AM »
Just a quick hub question from someone who's too daft to know.
If I want to change my front hub from a small flange to large flange do I have to put on a new set of spokes or can the old ones be cut down?
Bob_Acid
Team Admin
BMX Overlord
It's Bronked
Re: Hub question
February 03, 2007, 03:08 AM »
if you're going to bother replacing the hub i'd replace the spokes at the same time. but yes they should be fine if you want to use the old ones.
stidds
Site Supporter
My life is Radbmx
Posts: I am a geek!!
Re: Hub question
February 03, 2007, 04:50 AM »
I would imagine the old spokes will be way too long to lace to large flange hubs, if they are currently laced 3x then you may get away with lacing them 4x to use up the extra spoke length.
badbuckle
Re: Hub question
February 03, 2007, 05:02 AM »
Cheers for the info fellas.
jon016847
Re: Hub question
February 03, 2007, 08:40 AM »
yep you will either have th change the spoke pattern to see if you can get a fit, or get new spokes ..
Hub question
