975755
TattooedYorkie
September 23, 2024, 08:33 AM
Has anyone ever replaced the quick release rivets on an MX brake?
Topic: Has anyone ever replaced the quick release rivets on an MX brake? (Read 574 times)
mivvi
Curb Endo
January 30, 2007, 08:56 AM »
I got a set of MX1000s that are stripped and ready for painting. Im in two minds about removing the quick release levers so I can paint them properly. Its just not going to look as neat when I have to bolt them back on again though. Has anyone tackled this task before? Can the studs be bought does anyone know? Cheers!
dordymush
Berm Worm
Re: Has anyone ever replaced the quick release rivets on an MX brake?
January 30, 2007, 09:24 AM »
if im not mistaken the stud needs a special machine to put them in with.
i supose if you could get a rounded bolt that was short enough. it would look good.
mivvi
Curb Endo
January 30, 2007, 09:44 AM »
Yep, rounded bolt might be the way to go? Thought it was worth asking anyhow. Thanks for the reply Dordy.
Moose
540 Air
January 30, 2007, 07:58 PM »
You used to be able to buy hand riveting tools that were basically two half-spherical 'punches'. You put one in a vice, place the rivet in it along with the items you're riveting together, then place the other half-spherical 'punch' on top and hammer the rivet to a dome shape
Hope that made sense?
mivvi
Curb Endo
January 31, 2007, 07:12 AM »
Hi Moose. I know what you're saying and it sounds a viable solution to me. I got a tool here to insert rivits with a hole in like you would find in shoes for the laces to go through. The same principal really but need something a bit more heavy duty and without the hole, lol. I will have a look at some suppliers on the net and let everyone know if I do find something.
