975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 05:56 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  looseball bb question
Author Topic: looseball bb question  (Read 766 times)
selfpreservation
« on: January 06, 2007, 10:25 AM »
having probs with my looseball bb can anyone give me a description of how to install it , do the bearing races fit into the bb shell ball side in or ball side out ?
gt0733
Re: looseball bb question
« Reply #1 on: January 06, 2007, 10:46 AM »
the open side of the balls run on the cones, meaning the cages should be towards the cups on both sides.
selfpreservation
« Reply #2 on: January 06, 2007, 11:05 AM »
are you sure?
« Reply #3 on: January 06, 2007, 11:09 AM »
are you sure?
It should be just as it is in Biagio's picture.  Can you post a picture of how it looks on your frame?  Silly question, but are the cups pressed all the way into the frame?
Offline Nosnod
« Reply #4 on: January 06, 2007, 01:01 PM »
Installation guide for Flight cranks - Hope this helps!
http://ajkbikes.com/downloads/techtips/techtips.htm
selfpreservation
« Reply #5 on: January 06, 2007, 06:11 PM »
thats the wrong way round according to the redline instructions and all my senses  :LolLolLolLol:
selfpreservation
« Reply #6 on: January 06, 2007, 06:14 PM »
ive installed them properly i knew i had anyway gonna have to skim the nut down i reckon
Offline jT Racing
  • i like bikes. :/
« Reply #7 on: January 06, 2007, 07:13 PM »
they are usually standard ciaron. make a pic. you shouldn't have to touch a thing.
ding dong
selfpreservation
« Reply #8 on: January 06, 2007, 09:15 PM »
OK MY CAMERA IS CRAP CLOSE UP BUT HERE GOES
THE LOCKNuT IS STOPPING THE CRANKS FROM BUTTING UP CORRECTLY ive followed the installation instructions and the BB is spinning beautifully the cups are in correctly there is no play in the bb if i tighten anymore the cranks become stiff to turn i havent installed loosebal flights before but ive done loads of one piece and it seems correct to me , if i ues the original drive side cone it fits perfectly but because the mongoose bb has a raised nut instead of being slotted and therfore flat those extra couple of mm are stopping the crank from butting correctly onto the spline  :'(
gt0733
« Reply #9 on: January 07, 2007, 12:52 AM »
are you sure?
yep.exactly the same as a one piece install.
Trev
« Reply #10 on: January 07, 2007, 01:08 AM »
selfpreservation, you are right...... your camera is crap close up  :LolLolLolLol:
