975755
TattooedYorkie
September 22, 2024, 02:42 AM
3 piece crank question?
Topic: 3 piece crank question? (Read 577 times)
daz bmx it!
January 04, 2007, 11:02 PM »
I have two drive side crank arms so Can you cut the spider off the drive side crank arm and put it on the other side to make a set?
its an alloy one like a suntour or maxi cross?
CD17
Berm Worm
Re: 3 piece crank question?
January 04, 2007, 11:05 PM »
Think the pedal thread will be wrong
January 04, 2007, 11:13 PM »
Quote from: wish id kept my TA on January 04, 2007, 11:05 PM
it will definately be wrong
unless you fit 2 right hand side pedals
but that would be fruity
you could put a RH spindle in a LH pedal
lot of fanny arsing around though
daz bmx it!
January 04, 2007, 11:14 PM »
I got loadsa pedals
January 04, 2007, 11:20 PM »
get sawing then daz!
daz bmx it!
January 04, 2007, 11:21 PM »
Ah feck it! to much like hard work then
