975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 02:15 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  MX 1000 parts breakdown "now with full discription"
Author Topic: MX 1000 parts breakdown "now with full discription"  (Read 610 times)
DR VINOAH
« on: December 21, 2006, 07:24 PM »
its all here
complete
so if your looking for a thingy bob :'(
or a whats its name ::),
this pic will help :coolsmiley:
from left to right,in my own words  :daumenhoch:
1, lock nut ( holds the whole brake to the bike )
2, washer ( place under above lock nut )
3, concave washer ( place top side of brake bridge )
4, concave washer ( place bottom side of brake bridge )
5, spring ( connects to back of brake via part 12 )
6, wienman semi auto adjuster ( bolts onto dog leg of part 17 )
7, dome nut ( bolts to front of caliper )
8, flat nut ( bolts behind part 7 )
9, washer (goes behind part 8 ,stops flat nut from chewing up caliper )
10, washer ( goes between calipers ,helps caliper to move )
11, washer ( goes to back of caliper ,protects rear of caliper from spring )
12, centre bolt (note this is shorter hence a rear,short thread to the front,long thread to the back,
                        fix part 5 to slotted cut out )
13, caliper left hand side ( including the quick release mechanism and cable anchor  )
14, cable anchor bolt ( has a hole for cable to pass thru and bolts to cable anchor )
15, cable anchor washer ( fixes to back of cable anchor part 13 )
16, cable anchor dome nut ( very important holds cable tight )
17, caliper right hand side ( includes dog leg for weinman adjuster )
18, brake block ( ensure always free of dirt and oil/grease )
19, dome nut ( fixes part 18 to part 13 )
20, washer ( protects part 13 from part 19 )
21, brake block ( same rules apply as part 18 )
22, dome nut ( fixes part 21 to part 17 )
23, washer ( protects part 17 from part 22 )
thats all he wrote......................enjoy
« Last Edit: December 22, 2006, 04:23 PM by VINOAH,S ARK »
Offline danny silverstreak
Re: MX 1000 parts breakdown
« Reply #1 on: December 21, 2006, 08:09 PM »
i need long bolt thingy
Offline bodamus
« Reply #2 on: December 21, 2006, 10:58 PM »
I think I have a long bolt thingy.
From bodamus :)
« Reply #3 on: December 22, 2006, 01:58 PM »
was there a description with that too?
DR VINOAH
Re: MX 1000 parts breakdown with full parts discription
« Reply #4 on: December 22, 2006, 04:22 PM »
sorted :daumenhoch:
Re: MX 1000 parts breakdown "now with full discription"
« Reply #5 on: December 22, 2006, 05:06 PM »
man, you are committed. and should be! lol
DR VINOAH
« Reply #6 on: December 22, 2006, 05:38 PM »
 :2funny:
make it a sticky :daumenhoch:
