975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 06:50 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Tuff wheels question.
Author Topic: Tuff wheels question.  (Read 692 times)
Offline aditup2004
« on: December 20, 2006, 04:51 PM »
Were tuffs ever shipped from the factory with alloy hubs, but with the hubs bolted in, instead of rivetted? I have just recieved a set from a reputable source, and tho the wheels look in absolutely mint condition (you can tell they have never been ridden or mounted) the front has got a bolt in alloy hub, without the plastic tube thing between the bearing cups. The wheels were sold as NOS. What do you think?
Ad  :daumenhoch:
Offline Waxintaxin
Re: Tuff wheels question.
« Reply #1 on: December 20, 2006, 04:55 PM »
no chance , why would they do that ?
Unless its a NOS rear turned into a front but skyway wouldnt of done it
Rich
Offline aditup2004
« Reply #2 on: December 20, 2006, 05:01 PM »
Cheers Rich. Would you take it up with the supplier?
Ad
Offline Moose
« Reply #3 on: December 20, 2006, 05:25 PM »
UK made tuffs came with bolt in alloy hubs (apparently), but if the rear is a riveted hub then they're not a 'true' pair.
I bought a NOS set from Biagio that had a riveted rear and bolted front, which as it happens, turned out to be a blessing in disguise as I also had two NOS fronts, so I swapped the bolted front for a rear and made two pairs  :daumenhoch:
Offline aditup2004
« Reply #4 on: December 20, 2006, 05:36 PM »
So to summarise, I have still got a NOS set, though not a true pair.
Only the anal amongst us would be bothered  :LolLolLolLol:
Cheers, Ad
Offline Moose
« Reply #5 on: December 20, 2006, 05:42 PM »
Probably - it's possible that the front is a converted rear. I think if the front was a UK tuff, then it would have 'made in the uk' on it (although I'm not 100% certain of that)
Offline Nosnod
« Reply #6 on: December 20, 2006, 07:07 PM »
They have been discussing something similar on osbmx
http://www.os-bmx.com/forums/index.php'showtopic=22464
