975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 01:50 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  help needed with mag bleaching
Author Topic: help needed with mag bleaching  (Read 500 times)
DIVOT1
« on: December 09, 2006, 06:16 PM »
can anyone give me any guide lines on how to bleach white mags :daumenhoch:
Re: help needed with mag bleaching
« Reply #1 on: December 09, 2006, 07:40 PM »
Get a large sealed container big enough to put your wheels in, add several bottles of cheap, own label supermarket bleach and some water to cover the wheels.  If leaving the hubs on the wheels take out the axles and bearings, cover in grease (bleach blackens alloy) and drop them in, stirring every couple of days.  More detail can be found in the "sticky" restoring tuffs thread above  :daumenhoch:
« Reply #2 on: December 09, 2006, 07:50 PM »
stick some bricks between the spokes if you can, will save you on bleach
b and q sell a "big tub" for about a tenner. it fits mag wheels in it!
« Reply #3 on: December 09, 2006, 09:17 PM »
hubs will rot. unless you really cover them. i have found an excess of copper grease to be good at defending against bleach.
selfpreservation
« Reply #4 on: December 09, 2006, 09:25 PM »
ve found that cleaningthe mags well then submerging them in a water/bleach solution in a large bucket partially (not  covering the hubs )and turning occasionly works initially, then put them in the bath and pour raw good quality bleach domestos  on them covering them completly, leave until white , then turn over and do the same on the other side any stubborn bits after this just attack the areas with raw bleach and leave until white
