975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 05:51 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Does anyone know the bolt sizes to make up the hardware for flights?
Author Topic: Does anyone know the bolt sizes to make up the hardware for flights?  (Read 549 times)
mark j
I had a hardware store try it all out on a 401 flight crank a while ago a write it all out. And I've lost the paper. Does anyone know all the bits and bobs and is it all unc and can just be measured with a tape measure and some common sense? Please help!
thanks
mark
Re: Does anyone know the bolt sizes to make up the hardware for flights?
« Reply #1 on: December 09, 2006, 09:52 AM »
Go to www.customriders.com they stock flight crank spares i.e. washers, dome bolts, pinch bolts etc.  Cheap too.
mark j
« Reply #2 on: December 09, 2006, 04:24 PM »
Thanks Sean, From what I've worked out so far.....
Pinch bolts - 1/4 x 1/2 unc socket bolt
Arm retain - 3/8 x 3/4 unc button bolt
Chainring retain - 5/16 x 1/2 unc button bolt
And to replace stem bolts on a Hutch 5/16 x 1"
Went to a local hardware place yesterday and for 4 stainless bolts for the hutch stem was................£36!
« Last Edit: December 14, 2006, 03:15 PM by mark j »
