I built this with Richie Anderson's 1979 bikes in mind. It's not really a replica, but it's pretty close. Richie's was red, not blue and he had a pretty special one-off frame with the brakes on the chain stays.
Frame: Anderson Avalanche, OG nickel, OG stickers
Fork: Redline Microline, NOS
Headset: Frankenstein Schwinn, Tange and Hatta parts
Stem: Tuf-Neck
Bars: Redline Microline V-Bar, OG finish
Seatpost: VDC fluted alloy
Saddle: Kashimax MX
Seatclamp: Suntour
Cranks: Campagnolo Strada 175 with Sugino, drilled, 51T chainring, Campagnolo chainring bolts, Campagnolo crank caps
BB: Torker sealed
Freewheel: Suntour, 3/32" 18-tooth
Pedals: Reedy
Chain: Regina Drilled
Wheels: Araya 7b front, Araya 20 x 1 1/8” rear, Suzue hubs
Tires: Mitsubishi Comp II 20 x 1.75 front, 20 x 1 1/8” Swallow rear
Brakes: Mafac center-pulls with Kool Stop Continental pads, Dia-Compe Quick Release cable hanger, Campagnolo cable clamps, Pre-Bent Dia-Compe with rubber sleeve
Grips: A’me Bubble Font Tri
Other: Vinyl frame and handle bar pads, Tuf-Neck stem pad, 44-16 Designs Handmade Replica number plate
