975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 11:07 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Foil decal removal
Author Topic: Foil decal removal  (Read 1360 times)
Foil decal removal
« on: December 03, 2006, 09:52 PM »
Clear back decals = hairdryer .
What about foil back decals ? . I'd like to try & save at least one if poss to be able to scan , can it be done or does the foil disintegrate (sp) ?.
Offline kdw712
Re: Foil decal removal
« Reply #1 on: December 04, 2006, 09:29 AM »
matt i used a hairdryer on some but they do rip and tear and lot easier
so prehaps theres a better way
cheers Kev
Jazzchimp
« Reply #2 on: December 04, 2006, 09:33 AM »
Lighter fluid - from the tobacconist
Never fails!
« Reply #3 on: December 04, 2006, 09:36 AM »
matt just do what ever you try slowly they can be saved but not all
as they fall to pieces fluid or hairdryer .good luck
« Reply #4 on: December 04, 2006, 09:53 AM »
Never fails!
Carl ,
Lighter fluid ?
Jazzchimp
« Reply #5 on: December 04, 2006, 10:14 AM »
Yup, it melts the adhesive and the foil will simply drop off without and damage. Once it's evaporated you have a perfect decal in your hands. Trust me
Not sure how you can adhere it back on again. We use 'Spray mount' but that if only for card
« Reply #6 on: December 04, 2006, 10:28 AM »
Sounds cool , how do you apply the lighter fluid ? , wipe on ?
« Reply #7 on: December 04, 2006, 10:33 AM »
1 tip   dont put it in the lighter first   ;)
« Reply #8 on: December 04, 2006, 11:09 AM »
Jazzchimp
« Reply #9 on: December 04, 2006, 11:31 AM »
It's got a spout and made by swan  ;)
« Reply #10 on: December 04, 2006, 12:34 PM »
Put fluid on a rag and wipe decal ?
Jazzchimp
« Reply #11 on: December 04, 2006, 01:22 PM »
You can flood the edge and the decal will start to lift - then you can pour it under the now lifted corner and continue along - works every time. It won't damage the decal but will melt the adhesive.
DO NOT SMOKE WHILE ATEMPTING THIS!!!!
« Reply #12 on: December 04, 2006, 01:56 PM »
Thank you Carl , you are a Gent  :daumenhoch:
Now where's my lighter fluid , cigarette anyone  :D ;D
DR VINOAH
« Reply #13 on: December 04, 2006, 03:23 PM »
kaaaaboooooooooooooooooooommmmmmmmmmmmm ;D
« Reply #14 on: December 04, 2006, 03:53 PM »
You know that Steve !
 :LolLolLolLol: :LolLolLolLol: :LolLolLolLol: :LolLolLolLol: :LolLolLolLol: :LolLolLolLol: :LolLolLolLol: :LolLolLolLol: :LolLolLolLol: :LolLolLolLol: :LolLolLolLol: :LolLolLolLol: :LolLolLolLol: :LolLolLolLol:
burnaliser
« Reply #15 on: December 04, 2006, 04:07 PM »
Lighter fluid should work perfectly, I use it to get video shop labels off old videos that I collect and it always takes the stickers off without damaging the sleeves at all, so should be fine :daumenhoch:
