975808
V6 DOW
November 25, 2024, 06:51 PM
How do you open up a Gooseneck stem , without
Topic: How do you open up a Gooseneck stem , without (Read 868 times)
AL
November 25, 2006, 10:54 PM »
Silly question ?
But how do you open up a Gooseneck stem, with out breaking it.. To fit on a set of Bars with a cross brace..
RATTY
Double Flip Whip
Re: How do you open up a Gooseneck stem , without
November 25, 2006, 11:00 PM »
The bars will have the cross brace pinched, ie there is a flat bit on the brace which will allow you to slide the bars in, You wont open the stem up enough to get a standard bar through!!
Steve P
900 Air
November 25, 2006, 11:21 PM »
Here's a pic of the pinched cross bar if it helps
Steve
AL
November 26, 2006, 03:52 PM »
I meant if the bars have not go the pinched bit?
retrogeezer
November 26, 2006, 07:49 PM »
then you can't fit them....they are designed for the pinched bars.
jT Racing
BMX Overlord
i like bikes. :/
November 27, 2006, 09:56 PM »
you could wipe yer arse on it first to soften it up.
ding dong
dj_benice
November 27, 2006, 10:03 PM »
pmsl this is not the 17th century
