975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 25, 2024, 10:33 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  PK RIPPER BRAKE PROBLEM.
Author Topic: PK RIPPER BRAKE PROBLEM.  (Read 1150 times)
« on: November 23, 2006, 02:44 PM »
right i've got an early 80's ripper.
i've just bought a nos dia compe mx 900 brake but once fitted it seems miles to short to reach the rim.
i've pushed the wheel right up as far as it will go.
but its still not proper on the rim with blocks.
anybody else had this problem.
i see there a couple of rippers in the museum that have the brake mounted underneth instead.
dave.
Re: PK RIPPER BRAKE PROBLEM.
« Reply #1 on: November 23, 2006, 02:47 PM »
i think the mx1000's have a longer reach!
got one of them you could try?
« Reply #2 on: November 23, 2006, 02:56 PM »
no gra i aint.
i think that might be the problem as me and dan harris were talking about it.
i did'nt think it would make that much difference.
a small flat peice with a couple of holes drilled in might be good.
just drop it that extra bit.
zed4130
« Reply #3 on: November 23, 2006, 02:59 PM »
you need the mx1000 its longer  :daumenhoch: but i gues you know thay now  :crazy2:
Tony S.
« Reply #4 on: November 23, 2006, 03:00 PM »
You do see a lot of PK's with the brakes mounted under the brake bridge because most brake arms are too short. MX 900's will fall short more than likely if mounted on top. I have one with MX 900's on top and the wheel pretty far forward in the dropout and they barely clear.
I also have 1 PK with MX 1000's ,and one with Shimano Tourney's and they all barely reach where they are mounted. They are mounted on top of the brake bridge with the wheel in the middle of the dropout.
« Reply #5 on: November 23, 2006, 03:05 PM »
cheers tony  :daumenhoch:.
seems a common problem then.
i'll have to make do with it for a bit.
Offline jT Racing
  • i like bikes. :/
« Reply #6 on: November 23, 2006, 03:06 PM »
just use longer spokes and you should be ok. ;)
ok ok. yep you need 1000's or 1 3/8th wheels.
ding dong
« Reply #7 on: November 23, 2006, 03:28 PM »
What colour is the MX 900, as I have a few MX1000's & could do with a shorter brake on some of my builds.
zed4130
« Reply #8 on: November 23, 2006, 03:39 PM »
dave your ripper is faulty you should give it to me  :2funny:
Offline jimwise68
« Reply #9 on: November 23, 2006, 03:48 PM »
I've got the same problem with a Hutch Pro Racer.
Got an 890 on the rear, the wheel is as far back as it goes and the brakes just touch the edge of the rim.
I could do with a MX100 in blue or red for the back any condition is good as it is a rider.  :daumenhoch:
« Reply #10 on: November 23, 2006, 04:13 PM »
Quote
its a nos gold one chris.
just got it off biagio this morning.
« Reply #11 on: November 23, 2006, 05:53 PM »
Quote
Sorry mate only got Blue, black & silver  :(
« Reply #12 on: November 23, 2006, 07:05 PM »
Quote
gutted. bet that was worth a few bead stringing sessions....
i may have a silver mx 1000, ill have a look, but im not promising...
scottyp
« Reply #13 on: November 23, 2006, 11:27 PM »
i know your pain, i have waited for what seems a lifetime to get me hands on a looptail ripper, but i found exactly the same problem. i mounted a tourney on the underside, but it just doesnt seem right.
so i have got 2 rear MX1000's on order to try and resolve this!
will keep you posted.
cheers scott
Offline brass monkey!
« Reply #14 on: November 24, 2006, 11:43 AM »
i'm glad you raised that !  :)
I am building my 1st Looptail, and was considering MX900 ! hmmmmm ! MX1000's it is, better save some more then  ::)
FuNMoNsTeR
« Reply #15 on: November 25, 2006, 11:25 AM »
I have the same probs on my Torker rear brake...its a DC MX 901 and half touches the rim and tyre so i cant use it.  :(  Saving for a Black Mx1000  >:(
  My mates Ripper has a Blue MX1000 mounted underneath the brake bridge and reaches fine :daumenhoch:
« Reply #16 on: November 26, 2006, 04:01 PM »
i got a pair of diacompe 1020 's gold used tho lol
