975808
V6 DOW
November 25, 2024, 09:23 PM
cups and bottom brackets
Topic: cups and bottom brackets (Read 500 times)
Badbaldie
900 Air
November 18, 2006, 06:45 PM »
ive got a pk ripper with a one piece crank. if i up grade to a 3 piece crank will i need to change the cups? or will the bearings and bottom braket sit in the old cups? (never changed a crank b4)
Steve P
900 Air
Re: cups and bottom brackets
November 18, 2006, 06:52 PM »
If you're upgrading to an open bearing 3-piece crankset chances are the bearings will fit the 1-piece cups
Try the new bearings before knocking the old cups out
Steve
