975804 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 05:37 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Axle to nut probs...
Author Topic: Axle to nut probs...  (Read 613 times)
othomas2
« on: November 13, 2006, 09:29 PM »
I've got some tuffs with brand new axles... it's all there (cones/lock nuts etc) & fits hunky dorey.
But, my prob is that the normal skyway nuts wont fit ...  :-\ I assumed they'd be the standard 10mm skyway nuts.
It threads so far and then tightens too much, unless it's forced !!!
Not sure what's going on ... any help would be much appreciated.
My knowledge on this is limited.
thanks
Owen
Re: Axle to nut probs...
« Reply #1 on: November 13, 2006, 09:31 PM »
26 tpi you might have 24tpi
selfpreservation
« Reply #2 on: November 13, 2006, 09:34 PM »
try some ordinary wheel nuts , apparently some of the plastic hubbed ones the fronts have  26 tpi ata the front and 24tpi on the back , or someone may have used ordinary axles in them
othomas2
« Reply #3 on: November 13, 2006, 10:40 PM »
They were the ones you sold me.  :LolLolLolLol:
Was gonna PM you to see if you knew...
thanks for the info so far...
